Texecom Premier Elite 8XP 8 Zone - Speaker Not Working
27 Jul 2021
Hello all,
I've currently got a Texecom Premier Elite 48, I've just added a CCB-0001 with 16 ohm speaker to the network. The speaker worked for a few weeks but doesn't work at all now (chime, fire or alarm), other speakers on the system all work fine. I've replaced the speaker and there's still no sound.
Is it possible to test if the expander has a fault before I buy a replacement expander? The zones connected to the expander all still work fine, just the speaker output is not working.
Have you made any programming changes since ? Local or by wintex ?
If so re check what areas the speaker is assigned to on that expander
The speaker seems fine and I've swapped out for one that was working on another expander.
Something that I can't understand, the speaker sounds when the system arms/ disarms, but nothing on chime, fire or alarm. As far as I can tell it's set up correctly in Wintex, does anyone know of an option that would mute chime, fire and alarm on one expander?
I've also tried changing the position in the network in case that was the problem but it made no difference, I think I'll have to buy a new expander and see if that fixes it
I've just double checked speaker tones, everything's turned on. It's very odd because it's only one extension speaker that's not making all the sounds, but at the same time does make some (which is why I'm not convinced the expander is broken)
Problem solved! I'm not sure why but my Wintex and device were completely out of sync, I removed the saved file from Wintex and received the data from the panel on a fresh file. This let me set up the expander correctly. Thank you all for your help.
