Bosch dishwasher, doesn't always empty
26 Sep 2006
Dorset
Its a few years old now but started only emptying intermittently, cleaned the pump and hose although not really dirty. Once the cycle has finished if you start it again it empties.
I noticed that the plastic tank/pipe connector on the LH side is sometimes partly full of water.
Any suggestions?
Peter
Does the pipe go up to above the drum before connecting to the waste, to prevent syphoning back into the drum?
Like this.
They often have some kind of sensor like a vacuum device to tell when the drum is empty try a google for water level sensor or similar for your machine it might well be a blockage in that clear tank you mention.
Run out of ideas now, bought a new Beko, very good for the price. Thanks for all your suggestions.
Peter
Thanks for the update, have a Beko myself and been pleased with it.
