Hi, I found this (Pic 1) under my son's floorboards so I thought I'd tidy it up and put it into a connecting box (Pic2). As there are a lot of cables it was quite tight, is there a better way to do this? The cables are 1.5 T&E for the lighting. Thanks
Well, the enclosure does not really matter - back box with blank cover or junction box - but either way the cable sheaths should enter the enclosure (grommets on the back box) and cables be restrained so they cannot be pulled out, and boxes must be maintenance-free if to be inaccessible.
Yes I wired it in wrong, one of the reds is in the wrong place and the sitting room lights don't work I'll have to try and find which red it is, is there an easy way to check other than trail and error? I have a multimeter. The black was not attached and just loose so I didn't put it back, everything else works OK.
i haven't see the "surewire" product, but there is a handy surface box used by boiler fitters, they call it a wiring centre but it is just an insulated enclosure with lots of connectors inside. Some of them are groupled or labelled for "timer" "pump" "motorised valve" or something, which you don't need, but the way the cover comes off makes them very easy to use, and they usually have lots of knockouts and cable grips.
particularly handy in a bathroom or cloakroom where you want to run one or more lights, a timed fan, a heated mirror, a shaver socket etc.
or a kitchen with hood, concealed lighting, spots etc
BTW your metal box needs grommets in all the knockouts or the sharp metal edges may chafe the cables.
I tried a surewire product and I wasn't impressed, it's inflexible (I knew this before I bought it) but also the terminals were a PITA to get the wires into.
The hager MF boxes are great for simple jobs but 4 terminals is not enough for everything.
The wagobox lineup allow solving a lot of wiring problems in a MF way, but specifying a combination confusing to say the least. There are at least 3 different types of slot, classic slots for the 222 and 773 series wagos (which can also be used with adapters for 221-4 and 2273 series connectors), specific slots for 221-4 series connectors and specific slots for 2273 series connectors. And they don't seem to want to tell you how many connectors you can fit into each slot.
Yes it would be inaccessible, the wago 221 series would seem a good idea, I've seen the Wagobox XL 115x135x55. Anyone have any experience with these, any draw backs?
