Thanks, I've removed everything and cleaned out all traps and pipes. Outlet goes direct outside to drain, nothing else connected.Sounds like partial blockage , check inspection chambers , sink traps etc
Thanks Andy, outlet goes direct to open drain, all clear and cleanHave a look in the manhole.
Andy
Yup, that'll do it, straight swap if it's replacing an existing P trapIs this suitable?
Difficult access to measure, will it be 40 mm under a sink?Yup, that'll do it, straight swap if it's replacing an existing P trap
