Texecom Premier Elite - constant non-stop beep
24 Aug 2021
I have recently installed a Texecom premier Elite kit-0002 64 zone in my house. Everything seems to be working perfectly. The only issue I have is when I arm the system through the keypad the main control box make a non-stop constant beep. I cannot figure out the reason specially that I do not have this issue when I arm the system through the app.
yeup open e/e door tone changes close door changes 8 seconds (exit settle time) later arms confirmation tone when armed
@secureiam thank you man -I had defined the sensors incorrectly - change the front door to access/exist and it all work nicely now - thank you again.
Engineer code….zone set up scroll down , area programming ….press yes…timers , scroll down , arming mode , press yes …..what does it say ?…..now press menu , menu , reset , yes
