It's not the lamps!
It's probably not the fuses, as it seems there's one for each lamp.
Both main beams work properly.
Both parking lights, and both tail lights, work.
I suspect a relay, but as there is no indication of which relay or fuse does what on the fusebox lid then I will have to check every fuse and relay sequentially unless some kind soul can point me towards the location of an online wiring diagram.
MM
MM
