Recommendations for a good LED strip
18 Oct 2013
London
Could I please have some recommendations for a colour changing LED strip as I’ll need to buy this in quantity circa 70m.
Best I got was Lidi's own, but looking good and lighting room are not the same, the Lidi strip had a high lumin output, zigbee controlled but if not needed they your paying for something you don't want.
Most of that flat strip stuff i believe becomes problematic over 5 metres, over that i have seen the joints overheat, so you may need to break it down to numerous drivers drivers.
Led rope i think may be better for longer lengths, maybe opt for 24volt gear
Yes I was considering 24v and also I was told to run the cable from the driver to different sections of the length of the LED strips.
