- Joined
- 12 Sep 2021
- Messages
- 3
- Reaction score
- 0
- Country
Hi, I want to render the rear wall of a fireplace, prior to installing a wood burner.
The wall is approximately 70cm x 80cm and I want to apply 45mm of render.
To buy a ready mixed product I would need 66kg at a cost of £170.
Can I simply use sand + cement + lime instead?
If yes, what is the ratio of each?
The rear flue from the stove will be within 5mm of the wall when rendered.
