Burglar alarm chirping!
24 Sep 2021
Hi. I have a honeywell alarm system that started chirping away 2 nights ago. I have switched off the transformer at the socket and also disconnected the battery but it is still chirping away. Can anyone explain why please?
Is it the bell box outside?
If alarm turned off and still chirps, could be smoke detector in house ?
It is the outside box yes. I had no idea they had a battery in, I just assumed they worked of main power or back up battery inside the unit
...main power or back up battery inside the unit
it very likely has a rechargeable battery inside the bell box, maintained from the supply at the control box. It could be failing due to age.
Wireless systems are pretty sure to have replaceable batteries (some have a solar cell to charge it)
A bell/siren box has a battery inside it to raise the alarm if someone tries to cut its cable to silence it, in preparation for breaking into the house.
Thanks for your help all. Looks like I am getting the ladders out
If it's a Honeywell Renson8, get rid of it and change bell box.I would replace with Pyronix Delta bell E/Plus.
The cost of a Sab battery is equivalent to the price of a new bell box,plus the reassurance the the fault has been sorted.
