If you look you will see those two do not have any lables whereas all the others do.I had this new unit installed. Are all the switches meant to be like this? Some are up but some are down?
Thanks.
In pencil so it can be erased and relabelled if requiredHi Jeff,
As Winston states, the switches that are down are off, and if you aren't having any problems with your electrics, then there's nothing to worry about!
They are likely to be spare ways, but your electrician should have labeled them as such to avoid confusion!
Why did you not ask the registered electrician who installed the consumer unit?
on the electrical installation certificate that he/she gave you, what is the descriptions for circuits 3&8?
Don't know.Why has my reply disappeared?
What's that braided cable doing
More to the point "What's that braided cable doing that comes out from the inners of the CU"
I like the concept that an electrician can fit a new consumer unit and describe one of the circuits as "Unknown" on the electrical installation certificate.3 is Unknown and 8 is 'spare'.
