Wiring a doorbell.
26 Oct 2017
I have bought a Byron 776 door bell with internal transformer. Can anyone tell me which flex I should use from the wall socket to the the doorbell. I don't know the wattage but presumably it is under 720. If that is the case should I use 0.5mm (squared) 2 core flex? Grateful for any guidance.
There are no written instructions - only drawings. The drawing shows where to plug in the bell wires from the push-bell and where to plug in the L and N wires from the cable coming from the socket. There is no indication about the strength of the wiring from the wall socket to the doorbell which, I repeat, has a built-in transformer. Is it that the transformer will moderate the voltage and that any 3 amp plug and wiring for, say, a table lamp?
I should have said:
There are no written instructions - only drawings. The drawing shows where to plug in the bell wires from the push-bell and where to plug in the L and N wires from the cable coming from the socket. There is no indication about the strength of the wiring from the wall socket to the doorbell which, I repeat, has a built-in transformer. Is it that the transformer will moderate the voltage and that any 3 amp plug and wiring for, say, a table lamp WILL DO?
If you are plugging the transformer in, then a 3A fuse in the plug is needed. The cable from the plug to the transformer needs to be able to carry 3amp, so anything 0.75mm² or larger will be fine. eg such as that used for a table lamp.
The wire from the transformer to the bell and from the bell to the button will be the wire known (for some reason) as "bell wire".
RESPONSE TO TTC:
Thank you so much. The video was excellent; the appliance was exactly what I had bought; and with your help the installation went perfectly. I am a happy chappie.
Old thread but I have just bought a Ring Doorbell Wired and Byron 776 to do the same thing as in the video. The Byron chime is powered, it works with a standard bell button, but when connected to the Ring, the chime won't work.
How is it that it works in the video, I have wired it up the same?
Any ideas?
