Hello all
I am doing a like-for-like replacement of light switches in our home. Our bathroom has two switches - one for the ceiling lights and ventilation, and the other for LED lights around the cabinet mirror. The picture below shows the connections. One side is a simple 2 way module, the other is a double pole module.
I am looking to replace the above with the below switch modules. My question is - are the DP grid modules the same in both? The DP module for the current switch has N L(Load) and L(Supply) ports whereas the replacement show the ports as L1, L2, N1, N2. In which ports should the wires be connected to the new switch?
Thanks!!
Thanks!!
