I got this 22mm copper pipe, sitting in a 25mm hole in my cavity wall. But it needs to be sleeved, see. So I need to make a bigger hole, right? But you can't get masonry bits any bigger than 32mm (from ScrewFix anyway, and even that one's a special).
I got a diamond core cutting set for putting 100mm holes in me walls for extractor vents etc., but that uses a guide drill bit of about 10mm diameter. So, if I tried to put a 38mm core bit through the old hole, the guide bit would just waggle about in the 25mm hole, making it very difficult to hold straight. I bet this would produce an awefully messy result.
My question is: Without drilling a fresh new hole next to the old one, how do make my 25mm hole a 35mm hole?
