1 rad not working
24 Mar 2008
Birmingham
I Recently fitted a new rad in a new bedroom all the rads heat up fine apart from the hall rad which is stone cold. I have bled it and the opened the valves fully to no joy
any idea's please help
Turn all other rads off and just have the cold one on if there is any air in the pipework this wil force it out
thanks for that comment regarding turning the other rads off its working now thanks alot
Balance system up,,, as a rule of thumb upstairs rads makesure valves on flow (pipe that gets hot first) to rads are fully open and the opposite side lockshield/return are closed off then opened quarter to half a turn.
Downstairs open both sides fully. if some of downstairs struggle turn down the lockshield a bit at a time on the ones that are ok
