- Joined
- 21 Apr 2007
- Messages
- 58
- Reaction score
- 0
- Country
Hi,im putting a power shower in,it had one in some time ago,so the wiring is in,there is a feed from the cold storage in loft,just need to t into the hot from cylinder.question is,how far down from the draw off on top of cylinder to i need to t in? if its too high it wont draw off will it? and what size pipe? keep the 22mm right up to shower then 15mm or 22mm then stright to 15mm?
also the wiring is from the power shower to 3amp fused switch in airing cuboard? i wont do wiring,just asking.
can i use t with 2 22mm and one in 15mm to loft then down to shower?
ben
ben
