Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Where would you put ptfe around this if it were to leak. Have some rad. Valves to swap that are on these reducers. Swapping valves like for like. There is no olive as such. Thanks.
If they are the 'snap' reducer types then there's very little you can wrap due to the way they work. You can strip the valve and wrap the internals but it would be hit 'n' miss. Better to remake the pipe with a soldered reducer and or use native 10mm valves.
They're terrible things, I never use them. I only use the type that have a separate olive.
