I have been looking at a socket in my loft, which a boiler is plugged into (with a 3 amp fuse fitted to the 3 pin plug).
However, the wire supplying the power to the single socket appears to only be 1mm T&E - which I am unsure if this is a high enough rating.
To avoid having replace the underated(?) cable which is run via joists under carpetted floor boards, is it permitted to simply remove the plug socket, and replace with a "13 Amp Switched Spur with Flex Outlet and Neon - but fit this with a 3AMP fuse, meaning when the boiler is serviced the double pole switch is turned off and seen to be done by the neon light to isolate it?
Many thanks.
Many thanks.
