    Dismiss Notice
17th edition CU
Discussion in 'Electrics UK' started by sijaysee, 18 May 2008.
  1. sijaysee
    sijaysee
    8 Dec 2005
    344
    Thanks Received:
    Cornwall
    Country:
    hager 6+6 split RCD board fully loaded for £85 in my local suppliers but its huge!
  2. Sponsored Links
  3. SparkyMarky
    SparkyMarky
    4 May 2006
    135
    Thanks Received:
    Country:
    Believe me it needs to be! I fitted one of these (actually a Hager 7+5 + 1 unprotected from memory) a few weeks back and when all the ways are used (I had a couple of temporary circuits in at the time so had a full bank of breakers) there wasn't a lot of space left for the last couple of cables.
    I've got some pictures of it somewhere but think they must be on my other pooter...
  4. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    Hager CUs are easy to keep neat
    [​IMG]
  5. equitum
    equitum
    26 Sep 2006
    396
    Thanks Received:
    Coventry
    Country:
    Even if they are not installed in a compliant manner, e.g to IP4X ;)
    Even better to turn off the main switch before removing the cover ;) ;)
  6. sijaysee
    sijaysee
    8 Dec 2005
    344
    Thanks Received:
    Cornwall
    Country:
    RF you should win an award for that!
    Its gorgeous!
  7. kkynaston
    kkynaston
    18 Dec 2007
    319
    Thanks Received:
    Country:
    I have the same board, unfortunately it looks nothing like that...
    [​IMG]
    Was like that when we moved in, when I added the shed submain it fell off the wall :confused:
    Oh well, I see a busy weekend coming up :cry:
  8. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    I don't follow?
    how is my CU not IP4X compliant?
    It would have gone all dark then ;)
  9. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    IP4X on the top, IP2X or IPXXB to all other surfaces?
    If you put the cover on it might comply :LOL:
  10. Sponsored Links
  11. equitum
    equitum
    26 Sep 2006
    396
    Thanks Received:
    Coventry
    Country:
    The tails coming in from the bottom of the CU seem to have space big enough for a bit of 1mm wire ....
  12. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
    <edit> quote fixed
  13. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    Doesn't matter about the 1mm piece of wire as they are at the bottom. Only the top of the enclosure needs to be IP4X, the other surfaces i.e. the sides, front and bottom need to be IP2X or IPXXB.
    Bah, beaten by rob rob :LOL:
  14. plugwash
    plugwash
    28 Mar 2004
    9,528
    Thanks Received:
    374
    Country:
    wth is IPXXB?
  15. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    No rating for objects or water, but protection is provided against access to live parts with a standard test finger i.e. 12mm dia and 80mm long.
  16. equitum
    equitum
    26 Sep 2006
    396
    Thanks Received:
    Coventry
    Country:
    Please state the reg that details this. My understanding was that it was all sides of a CU, having said that In fact i'm not sure which if any reg says its IP44 an any side?!
  17. equitum
    equitum
    26 Sep 2006
    396
    Thanks Received:
    Coventry
    Country:
    412-03-01 & 412-03-02 :oops:
Loading...
Share This Page
