so I read up on the pros and cons on these very pages. I invest in enough cutting equipment to put a second channel tunnel in place
The Screwfix catalogue becomes my bible and I order 35mm metal back boxes like they are going out of fashion, so I can get the wires in without a struggle. As I engulf the house in a blizzard of dust I make a new discovery...
I dont have SOLID walls!
what I appear to have is a heavy concrete like plaster of about 5mm on top of a cream coloured soft stone second layer, about 7-8mm and then I have a cavity.
In short I've got nothing to screw the metal boxes to!
HOW DO YOU FIX TO SUCH A WALL?
I've tried a couple of dry lining plastic boxes but the ears arent deep enuff to fit behind 13mm of remaining surface?
do I tack/pin the metal boxes to the stone surfaces I can see? should I use something a little less violent than the SDS Plus and socket sinker kit? (as it destroys most of the surrounding outter layer in the process)
yours <cough> dusty & frustrated
