1st floor chimeny
30 Dec 2012
Essex
I have been renovating my girlfriends flat, re boarded all walls, celotex, new ceiling, new stair case etc etc...
It is a first floor flat set above a shop. In the lounge there is a chimney, this had a skim of bricks built Asa terrible surround, on removing these I discovered there was no lintel, I have fitted a concrete one. But it dawned on me that the chimney breast is on an outside wall, and is above a shop window. I.e no chimney underneath. I don't know If the building was built like this (1920's) or if a wall and bottom of the chimney was removed to fit the shop window some time ago. How can I check this? There is a cement hearth in the floor. I have looked through the shop window and cannot tell if there is a support installed. I don't want to ask in the shop as it will open a whole can of worms.
I've attached a pic but it's upside down!
Any advice?
Difficult to know without investigating from beneath. Its probably been done donkeys years ago and not going anywhere, but wouldn't pass any building regs today.
Thanks for the replies, no problem as far as I can see, this must have been done years ago as the shop windows are old style. I think there may bean RSJ in place but its hard to see. if I remove a couple of floor boards would I be able to tell?
Just with some of the other bodges I have found, such as voids round the window frames where the weight drop boxes had not been filled etc. it could be anything with this flat.
and thanks for sorting the pic.
