2 gang switch- com of one switch connected to L1 of other???
4 Aug 2006
Powys
I'm replacing an old 2 gang 2 way switch (used as 1 way however) and am slightly confused to the way in which it is wired. All the connecting wires are sheathed in red and there is a short connection between the 'com' for switch A and the 'L1' of switch B. Dont understand what the function of this wire is- the house is about 10 years old if thats relevant.
Also the 'A' switch controls 2 wall lights and the 'B' switch controls a ceiling light.
Any advise greatly appreciated.
dont worry about it, if you are changing the switch not my signature and change the switch.
it is a live feed by the way
Cheers for reply, but I'm still slightly confused- what is the function of the live feed? and should I just replicate this with my new switch?(this will mean a longer piece of wire howver because the relevant terminals aren't next to each other in the new switch as thay are in the one I'm replacing).
one day i WILL press the spell check button
the answer is in the question
live feed
it is the live that feeds (in your case) the lights
and yes you should and yes
to prove it, you could try this
disregard what i have said and put any wire in any terminall then wonder why it doesnt work.
The wires you have in your switch are wired that way so that it will work, do it wrong and oh dear, and now i will try again (getting the spelling right)
please note my signature (in other words use a marker pen to mark each cable before you take it out and make a drawing of it too, thn copy this to your new switch
damn :!: still got it wrong
