Just a few quick q's:
You cannot have a hot AND cold feed washing machine/dishawasher with a COMBI BOILER system can you? they need to be cold fed only?
also to tell if my powerhead to my 3 port valve is faulty is this an appropriate way to be 100% sure: i was advised this but i have my doubts!- test for voltage to my cylinder stat call terminal (number 1) with cyl stat turned up and programmer on for hot water. if fine and no hot water then I can take it my 3-port valve is faulty and not switching on the pump and boiler. BUT from what I have learned, the pump and boiler get energised from the cylinder stat calling and not the 3 port mid position valve moving/opening for hot water only? so how can i test/is this advice incorrect??!
