2 Shower pumps one cylinder
5 Jul 2006
London
Hi Guys
Need some advice please.
Job I am doing next week entails adding on a shower room with a thermo valve from a gravity hwc.
The current setup has a thermo valve with a pump from the cylinder.
Is it possible to run the 2 showers from one pump or can I install 2 pumps?
Not sure of the hwc capacity yet.
The client requires 2 showers in operation together with good pressure.
I am thinking 2 pumps would cause air to be pulled in even with a surrey flange or am I incorrect?
Could one pump feed the 2 outlets with reasonable flow and pressure?
Many thanks for your input.
Pete
can you not get a better pump, one that will be able to provide you with the amount of flow rate and pressure you require for both showers to work correctly, and get rid of the one that is currently there.
Yes I am hoping that is the best option just needed to clarify if I could feed two showers at once in terms of flow rate.
Cheers
Pete
Could fit 2 Essex flanges and uprate the cold feed supply pipe size from cold storage tank to hw cylinder.
