My central locking on my focus is somewhat a pain,
instead of it locking the doors at the same time it locks one then the other (about a sec apart) using the key fob,
if you push the lock when inside the car you cant open it using the inside leaver until you press the lock button into the unlock postion, and it's got to be the one you originally locked it with
The weird thing is.. it rights its self now and again, it can go months with it locking correctly then it does the above.
could this be the key fob battery, and can i just replace it or does it need to be programmed to my ignition barrel after battery replacement?
