Hello all, So heres the problem. My partner has bought a low voltage ceiling light which holds 10x 20Watt halogen bulbs poewered by its own built in toroidal transformer. I did the 10 minute job of fitting the light as a direct replacement for the old pendant, tested the light & on it came, no problems. Now if I switch it on and off a few times (not fast) it eventually trips. It also trips sometimes on the first switch on. There are obviously other lights on the ring, but none are turned on while testing this one.
The consumer unit is a "Square D" Quikline.
The mcb that the lighting circuit is connected to is a "C6" Can anyone help me on this?
Should I run it from its own free slot in the consumer unit? or is there an easier way out?
I'm positive that the wires are all in the right places & the light switch is a stainless steel \ hidden screws \ crabtree. (Not dimmable)
