Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
CFL lamps run at much lower temps than regular downlights etc...
Heat flex? You mean cable that is resistant to higher temperatures? No you do not need to use that.
Fire hoods are not necessary unless the ceiling is a fire check ceiling or if you are in a multiple occupancy building.
Don't forget however, that traditional Halogen lamps could be retrofitted at a later date, and so if they are new downlighters, making the same preparations such as removing insulation from around the fittings would be advisable as Halogen Lamps create far more heat.
I have plastic fittings that only accept CFLs. The CFL lamps have notches around their front, which correspond to lugs around the front of the fitting. These actually hold the lamp in - push it in and turn slightly.
