3 port valve stuck - need to change motor - HOW???
30 Oct 2006
Somerset
Can i ask if this is the right thing to get?
http://www.onlineplumbingsupplies.co.uk/acatalog/HoneywellMotor.pdf
I took a look at the bit in the airing cupboard and its honeywell V4073.
Is it easy to replace? inexperienced DIYer here. Any instructions on line??
Just to clarify - just this bit needs replacing and not the whole head replacement unit which i think looks like about £50.
Thanks again!!
Gav
6 Oct 2004
Just look at the picture in your link; there are 2 holes for fixing screws. So with your system turned off, take your old one off and replace with this, straight swop mechanically. Electrically, 2 wires. Again look at your existing one to see how easy it is.
25 Aug 2003
Surrey
if its stuck it aint likely the motor thats yer problem I would have said
can you move the spindle with your fingers?
30 Oct 2006
Somerset
I haven't actually taken it apart - just going on advice from a previous post...
Planned to look at weekend tho.
just to clarify the system works but CH comes on when the HW comes on. and the CH swich is OFF.
