4 Core Mains Flex - Harmonised Colours
23 Mar 2005
I have some 6amp 4 core mains flex with core colours black, brown, grey and green\yellow which I am using to provide 2 switched lives. Could anyone let me know the correct colour to use for the neutral.
Thanks.
use any colours you like, just make sure you mark each end with either brown or blue tape/sleeving. i normally use brown and grey as lives, black as neutral
the f*cktards at the niceic suggest using grey as neutral (thier reasoning is to try and break the black=neutral association in peoples minds) others think this reasoning is crazy and if using a cable with a black core and no blue then black is the most sensible neutral color
whichever you do make sure you mark the ends so people know what you have done
btw are you sure its flex you are talking about? i thought 4 core flex was brown black bllue green/yellow.
btw are you sure it is flex you are talking about? i thought i thought four core flex was brown bllue black green/yellow.
I think the I might have seen in a wiring regulations colour harmonisation ammendment that the colours of four core flex have slightly changed
