    Dismiss Notice
52mm washing machine hose connector?
Discussion in 'Plumbing and Central Heating' started by Ben S, 28 Mar 2021.
  1. Ben S
    Ben S
    28 Mar 2021
    Thanks Received:
    Country:
    Looking for a washing machine hose connector. There's a screw attachment on the existing trap with a blanking plug and nut.
    Blanking plug:
    • outer diameter: 39mm
    • inner diameter: 31mm
    Nut:
    • outer diameter: 52mm
    • inner diameter: 46mm
    • side which blanking slots into: 39mm
    I'm struggling to find a hose connector that fits. Previous owners left a McAlpine WMF3, which is too big (1½"). Also tried a FloPlast Hose Connector, which is also no good (40mm/1½").
    As a last resort, I've got a new trap (McAlpine WM11), but am unable to unscrew the waste pipe, neither by hand nor with some WD40 and pliers. Perhaps some plumbers putty was previously applied.
    Any suggestions here? Easiest solution seems to be a new hose connector. Anyone familiar with one of that size?
  2. terryplumb
    terryplumb
    8 May 2017
    5,674
    Thanks Received:
    1,159
    Country:
    The trap should unscrew from the rigid waste pipe quite easily ,are you sure you are turning the white nut the correct way ?
  3. Sponsored Links
  4. JohnD
    JohnD
    15 Nov 2005
    71,069
    Thanks Received:
    4,027
    Crossgates
    Country:
    Cook Islands
    Post a photo of the parts you are talking about. Include a measure or ruler to show scale.
  5. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,182
    Thanks Received:
    1,679
    Northamptonshire
    Country:
    Wondering if you're trying to connect to 32mm (1&1/4") waste, although unusual to find a 32mm trap with an additional connection. What is the OD of the waste pipe leading away from the appliance, and in fact, what is the trap currently connected to?
  6. Sponsored Links
Loading...
Share This Page
