    Dismiss Notice
aabout to tackle a house
Discussion in 'Plastering and Rendering' started by big t 09, 29 May 2007.
  1. big t 09
    big t 09
    12 May 2007
    5
    Thanks Received:
    Yorkshire
    Country:
    hi.im about to tackle my first big rendering job once the weather improves ive been a self employed plasterer for 18months and feel that this is an area would like to brake into. ive already done the odd garden wall but im unsure about how to add the correct amount of waterproof solution to the mix
  2. Sponsored Links
  3. FredFlintstone
    FredFlintstone
    19 Jan 2007
    543
    Thanks Received:
    Cheshire
    Country:
    Hi Big T,
    I've only been going alone for a short time and am way off rendering (tried it one helping a mate out and jeez, was it hard work). I'm relatively iexperienced and still have a whole load to learn.
    Would the correct amount to add not be stated on whichever waterproofer you're using?
    Regards
    Fred
  4. big t 09
    big t 09
    12 May 2007
    5
    Thanks Received:
    Yorkshire
    Country:
    probebley its just that ive not had to buy any yet and im trying to sort this guy a price out .
  5. Nige F
    Nige F
    28 Jun 2005
    21,047
    Thanks Received:
    1,716
    Country:
    try googling FEB admixes ;) they make loads of magic potions
  6. dougalhouse
    dougalhouse
    11 Oct 2005
    133
    Thanks Received:
    Bournemouth
    Country:
    Fill your bucket up to the 10 litre mark with water then check the ratio on the tub.
    If for example it's 30:1 then a coke can is 330 ml - cut top off with your snips and fill (just under full) with waterproofer add to water and mix thoroughly.
    Or you could buy a plastic measuring jug :!:
    Good luck!
    PS. Whole house - price for 2 i'd say.
  7. big t 09
    big t 09
    12 May 2007
    5
    Thanks Received:
    Yorkshire
    Country:
    cheers dougal. not priced for two but have priced 6 days, front back and gabel end.2 days each
  8. rdw exteriors
    rdw exteriors
    26 May 2007
    19
    Thanks Received:
    Bradford
    Country:
    im a plasterer, mainly doing rendering & dashing, where are u based? 4 - 1 ratio with a good measue of feb mix
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
