just attempted to wire up my new alarm system.
on zone 1, I have 3 shock sensors, one on each window, and 2 pairs of magnetic contacts, for front and back door.
connected everything in series, with 1 wire going from the panel to the furthest sensor, and the other wire looping into each sensor and out onto the next sensor..is this correct?
the system chimes fine when a door is opened, and when the shock sensors are activated.. no problems in terms of functioning.
but the system will only "set" if one of the doors is open, or shock sensors are activated.. so when the circuit is broken.
if the circuit is complete, the system wont "set" it just says, Setting Fault.
but as soon as I break the circuit by opening a door it Sets fine...
do I need an end of line resistor? if so which size?
Thanks.
Thanks.
