I'm about to have my loft converted to a bedroom and WC and have specified a storage area / tank room for existing cold water tanks and CH header tanks. Beginning to wonder if I might be better off moving to UV solutions at same time to avoid lots of tanks in Loft (I have 3)
House is 4 bed (will be 5), 2 showers in en-suite, bath, shower pump, 2 balanced 50-gallon tanks in loft fed via water softener in kitchen. Mains pressure good. Hot and cold all gravity fed to sinks and cisterns. Only mains cold to kitchen tap.
CH is Potterton Suprima to 17 rads with traditional cylinder in airing cupboard.
Loft conversion will involve re-plumbing 10 or so connections to newly re-positioned tanks and vents, re-sited at one end of loft away from airing cupboard. Plus CH header will need to be very high up above the loft bedroom radiators. Not sure how hot water will get to loft WC sink yet.
Is there a better solution than moving all this old technology stuff? Is an UV megaflow a better approach? Plenty of room in airing cupboard.
I could include roof mounted solar water heating at same time?
Space in loft is not an issue for tanks, but pipe connections might be tricky as lots of steel to go in for new structured floor.
What's the usual approach to this? Budget is £3 to £4k for plumbing - might as well do this properly whilst putting floors and loft conversion in. Would prefer not to change Suprima - mine works very well, no issues at all.
Sorry for long rambling question !
D
D
