I'm hoping someone can help me with this:
Is it possible to remove just the blower unit from the boiler without too much hassle? I want to be able to get at the lower bearing in the fan assembly but I need to get at the underside of the blower so I can get the impeller off the motor shaft so I can get the shaft out from the top (if that makes any sense!). I can't see an easy way to do it without removing the entire assembly from the pressure vessel. The 'snail shell' part of the blower is seperate from the rest of the assembly but I can't see how to get just this part off.
The reason being is that I had an incident with the fan motor/impeller bearings drying out over the weekend (started with an 'orrid noise then stopped completely yesterday) After letting it cool I was able to get some lube into the bearings and this seems to have cured things for now, but I think it will recur sooner rather than later. I begrudge paying £90 for an entire fan unit when I know the problem can be solved with 2 bearings that are about £2!!
Many thanks.
Many thanks.
