Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Depends if you want to be able to easily fix stuff to the wall. Aerated can be a PITA to fix cabinets etc to if this extension was to be used as a kitchen for example.
Aerated blocks are easier to handle as they are lighter and also offer some insulation meaning you nees less cavity insulation.
I need some advice about foundation fill. I don't know the exact depth/ width the foundations need to be as i'm at planing stages.
I have a few questions as to how i should tackle the whole task.
Do i have to fill the foundations with hardcore+ sand and then concrete fill on top of that?
As for wooden marker pegs used to level the concrete fill, do i leave in the foundation or do i pull them out once concrete has been laid?
