Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Can i connect 2 pieces of coaxial to one aerial? I understand if you split the cable you half the reception, but is this still the case if i connect directly to the actual aerial mounting?
If you do this, then you can cause a lot of undesirable effects. Some channels could disappear whilst others are OK, If you unplug one of the downleads, it affects the other, On analogue TV, it can produce ghosting etc.
With aerials and cables it is important to preserve the impedance match and this is what a proper splitter does. You will get loss no matter how you split the feed but a proper inductive splitter is the best option.
