Air coming out of hot tap
8 Feb 2007
Sheffield
Hello all
i've got a friend that has been complaining that when he runs his hot tap either down stairs or up in his bathroom that it was running and cutting in with air.
when i went to look at his system i found that the vent pipe on his F + E tank was sucking in air.. when i placed my hand over the vent pipe it started to run fine.. obviously blocking the release vent is not an option so does anybody have some ideas on how i can sort it out for him??
cheers
Remove the blockage - it will be in either the cold feed to the cylinder or the hot outlet at the top.
"the vent pipe on his F + E tank "
Do you mean the small tank? 18" x 12" x 12" or so?
This should have no relevance to tap water.
If you mean the big cold water tank, then yes, could be blocked. e.g. with a drowned mouse or pigeon, or loft insulation fallen in. I would have thought the supply pipe rather than the outlet, but Softus is one of the plumbing princes, even though he is just a lad.
Oh jeepers JohnD, that's going to bring some pretty meaty wrath from my elders and betters on the forum. :shock:
Perfect. I'm much more comfortable when being demeaned. ;)
The first time I came across this was in 1982 as an apprentice. I can still remember the house!
The culprit was a malleable iron elbow that was fitted on the feed pipe to the cylinder. It had rusted inside and created the blockage.
A restriction here causes air to be sucked in at the vent. I sussed out that if I put a temporary stop end on the vent that the problem would stop.
Slugbabydotcom said:
...It had rusted inside and created the blockage.
I concur.
And the same effect can be had by chipping off bits of foam lagging and dropping them into the cylinder - they bob-up and block the outlet. This is quite hard to do of course, but I guess there are people out there who practise until they've got it right. ;)
...beat that by 8 years :lol: and the other apprentice was left like the Dutch boy and the dyke...for an hour till we got back ...yep it broke off in his hand :lol:
