Hopeing for some help!
Firstly the system I have in my house - I have a main water talk in the loft, which feeds the hot water cylinder on the first floor. I have a water pump that feeds the hot water for the whole house connected off the hot water cylinder - so when any hot water tap opens the pump kicks into action.
So my issue I had a leaky hot water tap and turned the mains cold water supply off from outside my house and then emptied the water of the cylinder and main water tank in the loft. so no water was coming through my taps. I replaced the washer and then turned the water back on from the mains.
Now my hot water is not coming at all!
from what I have read already there is clearly air in the system but when I try the U technique with the cold water is just stops the pump working.
Any suggestions - I am not even sure the water cylinder is full - it definately has water because I hear it filling but doubt very much its full - I think it full of air! is there a way I can air it? so the pump is not effected!
completely lost and this is now day 2 without hot water....
