air noises from pump
30 May 2004
hi i have noises coming from my pump and rads after i use hot water or use the rads. it sounds like there is loads of air in the system also the boiled has overheated twice and needed resetting. i have bled the pump and the rads but no air seemed to come out. its starting to anoy me know the airing cupboard sounds like a toilet refilling all night!
any help appreciated
I would next ensure that there enough water in the system. When you say you 'bled rads and pump' did water actually come out? Or just no air? The symptoms you describe could be due to an empty F&E tank (easy)or a blocked cold feed pipe (trickier).
How did the problem first appear?
