Hi there,
I had trouble with my boiler which ended up being a failed pump which was due to the diverter valve.
I changed the diverter valve and pump and things seemed fine.
In October i turned the heating on and since the boiler seems to be a little noisy (sounds like an small aeroplane passing by) and the hot water keeps going cold then heats back up.
I took the covers off to have a look and the shower ran perfectly, but when i put the covers back on, the pilot light keeps going out -hence the cold water problem. Can anyone help?
It would make sense that there is air in the system due to the diverter valve replacement but why does the shower work fine with the covers off. How do i check for air in the system, do I bleed the rads ?
Thanks for your time -v.much appreciated
Steven
PS can I get a manual for the alpha boiler Alpha seem to have gone on the missing list.
Steven
