Anyone had a problem with this boiler where the dhw only stays on for a short while then cuts out then restarts. Similar situation to a dhw plate heat ex being blocked but its a twin pass heat exchanger. When it happens the top light flashes orange.
Ive rang manufacturers and they said either overheat stat, aps or pcb. Only fault i found was the over heat clip was a bit feeble and it looked like the ohs wasnt getting a good contact. However the customer says sometimes they can fill a full bath sometimes only half of hot water.
PS its in a hard water area too.
