Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
A friend of mine used it for joining copper and endfeed feetings on a piece of artistic furniture and it bonds well and looks very neat, but theres NO way id use it for plumbing/heating.
Have used it to give it a go, and decided it has less pros and more cons. It produces a very neat-looking joint and would be good in places where heat cannot be used, however if you don't put enough on or don't get a good joint and it leaks, it's quite a mission to dismantle it all again - with solder you can often just reheat and run a bit more in, with this you have to cut out and start adding in more fittings to repair. Also, there's very little repositioning time, so if you're in a tight spot you can find it's going off before you've got your pipework exactly where you want it. I certainly wouldn't use it over solder in most situations
