Apollo 15/30 b Replacement
7 Jun 2006
London
Hi
Could someone recommend a good system boiler as a direct replacement for my trusty old boiler. 30kw flow and return at top, horizontal flue. 10 rads.
Easy controls, easily maintainable, accessible parts, usual thing.
Regards
I'd probably stick a tried and tested Worcester Ri in (they've been around for 15 years and little changed).
Apollos were frequently installed below worktops...that's not so easy with modern boilers so expect to stick it higher up on the wall.
Hi All
Sorry for the late replies, my apologies, I meant to type Btu/h not KW. fortunately the Apollo is high up on the wall and having read the installation and service manual it seems to meet all the requirements.
Just had it serviced and gas safety certificated so no point in swapping yet but will look at the Worcester Ri.
All advice truly appreciated.
