Ariston FM27 MIX electric oven
3 Feb 2010
Belfast
Convection oven will heat normally to the set temperature but when fan/ventilated oven is selected then temperature will not increase beyond about 80 degrees. I don't have a circuit diagram and I'm not sure if separate sensors/thermostats/controllers are use for each selected mode of operation. Any advice would be greatly appreciated.
Check fan oven element,
Some fan ovens use a mix of fan element and convection element on some settings.
If the convection works normally it could be the fan oven element has blown.
Many Thanks Leccy758, I hadn't realised a separate element was used when the fan was on, but it does make sense.
I'll take the oven apart in a few days time when I'm off work and do a continuity check on the element.
- Hope I've posted this ok, it's the first time I've tried it!
