bar shower mixer support
15 Apr 2005
Yorkshire
I recently purchased a triton shower mixer, but have never used one before. I understand they are supported from behind, but it didn't come with any kind of support mechanism. Do I need to purchase a back plate to fit this securely? The shower will be mounted on a stud wall, which is completely open at the moment.
I've just fitted one, there is no back plate as it's expected (in the instructions) the copper pipes will be fixed rigidly and will hold the shower - it does if done properly.
You can buy a fixing plate if you really want to though.
There's a number of ways to do it.
A wall plate fixed inside the stud wall.
Or use 2 wall plate elbows then fit your 1/2" x 3/4" dogleg fittings.
Or use these, these are the easiest saves measuring finished surfaces of your board/tiles just fit your 2 15mm pipes then fit these after tiling finish.
So what fittings did you use to go from 15mm pipe to 3/4"" shower fittings ?
They're nice fittings, would certainly have made measuring up accounting for tiles/adhesive easier!
Triton's own fitting instructions tell you to ensure the pipes are rigid as this the shower support. I like those fittings better, although the way I've done ours has given it the necessary rigidity.
15mm compression elbow without the support back plate, again as per instructions.
The wall is dot and dab and was already chased from the previous shower. I redid the pipe work sleeved and clipped them to the wall and them foamed them in, they are rock solid.
I was considering just clamping the 2 pipes between studs instead of relying on plastic fixings, (the wall is of 2x2 construction and it built 6 inch from the brick wall, its sole purpose being to hide shower pipework, so i could screw another piece of 2x2 behind to clamp the pipes, not sure of this is a good idea.) But I may just opt for a plate, it looks neater.
