    Dismiss Notice
base cabinets
Discussion in 'Wood / Woodwork / Carpentry' started by BARCUD, 22 Dec 2013.
  1. big-all
    big-all
    12 Jul 2004
    18,972
    Thanks Received:
    1,490
    Surrey
    Country:
    dont pay any more than around £13-15 a thousand for 30/35/40mm x8mm dowels
    they should be just over 1-1.5p each
    • Thanks Thanks x 1
  2. BARCUD
    BARCUD
    18 Sep 2008
    163
    Thanks Received:
    Gwynedd
    Country:
    Don't you ever buy lengths of dowel and cut them to size? I spotted lengths of 6mm but perhaps 8 and 10mm lengths are more difficult to buy so you have to buy them ready cut, more expensive?
  3. Sponsored Links
  4. big-all
    big-all
    12 Jul 2004
    18,972
    Thanks Received:
    1,490
    Surrey
    Country:
    dowels are compressed beech with ridges a 8mm dowel rod in an 8mm hole will not work very well as glue is a fluid so trying to push you will get hydraulic resistance so no glue spread and nearly impossible to close up the joining surfaces
    • Thanks Thanks x 1
  5. BARCUD
    BARCUD
    18 Sep 2008
    163
    Thanks Received:
    Gwynedd
    Country:
    Interesting, thanks for the info.
  6. Sponsored Links
  7. gritmonkey
    gritmonkey
    27 Mar 2013
    27
    Thanks Received:
    Yorkshire
    Country:
    What Big-All says above is essentially correct. Though nowadays with the manufactured ridged dowels you can glue and dowel with a snug fit and you won't go much wrong.
    Whenever I need to use dowels I go the old fashioned way, just cut a piece off a length and plane a "V" shaped groove with a doweling plane(home made).
    What I would suggest, if you want to go down the route of saving a bit of money is to buy a length of dowel and put a flat on it with a block plane, then cut off to length as you need it. The flat you've planed will allow excess glue to escape.
    • Thanks Thanks x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
