Baseboard water heating
13 Dec 2008
North Dakota
I'm getting banging from my baseboard water heating system. I've bled all the valves at each baseboard with slight short-term improvement. The 3'' tall FLOW-TROL air release valve on top of what looks like a pressurizing tank is blocked. I have the replacement valve and want to know what I need to turn off before I unscrew the old valve. Also which side of the system should the zone controls be on, front or back and where do I introduce the pipe cleaning chemical since I'm sure this is also required.
this is a UK website and our plumbing and heating methods are different to yours.
banging pipes might be expansion and contracting (if so, clip them to the wall, or ease them is they are rubbing on joists or floors in tight holes) or it might be thermostatic valves shutting with a bang due to water pressure. If this is the case it will stop for a while if you change the setting up (so they are wide open) or down (so they are tight shut). older TRVs can bang when the are just on the poiint of closing and the water pressure grabs them (like a door blowing shut in the wind).
other bangs are more likely to come from scale or other deposits in the boiler, where they will be loudest, though the noise may travel along the pipes.
