Bath base board encapsulated?
6 Feb 2010
Blackpool
Hey I have a bath to fit were the base board. The part you screw your legs to. Looks to be under the fibre glass, is this correct. Don't want to screw in to this if it will cause a leak.
Thanks have never seen one with the base board is the fibre glass before. Do you say its quite common though?
Installed an acrylic bath recently where there was no base board, the bath had extra thick strips of acrylic that you screwed the feet directly into. It's a little unnerving the 1st time but after a few you realise that it's fine :)
