Dear All
I hope somebody can assist me, I have scoured the rest of this forum for an answer but not had any luck, so please forgive repetition! I have recently installed a combination extract light/fan over my shower in the bathroom. The unit consists of a fan and integrated light, and the light runs through a transformer. I have wired both up via a junction box with the appropriate switched live to a separate pull cord switch. I have taken the supply for it all from the lighting circuit, and fed this first into a 3Amp fused connection unit, as per the instructions that came with it. Because I have wired the FCU (think this is the correct abbreviation) from the lighting circuit, not at the light switch with a permanent live, the fan only operates when the bathroom lights are on. This in itself poses me no problem as i hate the noisy overrun!. However, my concern is that the FCU is wired off the lighting circuit and thus has no earth. (the original lighting circuit is not earthed) Incidentally the upstairs lighting circuit has a separate fuse on the fuseboard. Is the fact the the new FCU I have connected is not earthed a problem? Should I disconnect it from the lighting circuit and spur it from the first floor sockets ring instead so it has an earth? Or can I leave it as is? Any help most appreciated, fuse is out and not in use for now! Cheers
