bathroom cabinet fixing
5 Nov 2005
Manchester
Hi. Glad I found this place!
I need to put up a fairly heavy bathroom cabinet onto plasterboard with breezeblock behind. I thought it was brick behind until I drilled in and it was soft and grey! I can't see that the four screws supplied are going to hold the cabinet at all.
Any suggestions please?
cabinet pannel 6mm plasterboard 12mm gap 12mm plug 40mm
so 2.5 or 2.75 "8 or 10s or 70 or 80mm 4.5 or 5s
any measurments different ajust screw length accordingly
You wont go far wrong with 5mm (No10) x 100mm (4") screws if these dont hold it up try rawl bolts if it's that bl**dy heavy. LOL
Remember it doesn't have to be very strong as long the screw has gripped the rawlplug correctly with the right size. A little tip is to drill the hole downward slightly and it will hang without the rawlplug but don't do it though :wink:
