I am undergoing the installation of a new bathroom. The bathroom currently has a single light operated by a pull cord and an electric shower on its own 40A circuit isolated by a pull cord in the bathroom.
I intend to install additional lighting operated by a dimmer switch outside the bathroom.
An electric fan operated by a switch outside the bathroom.
An electric light over the sink.
A shaver socket with a transformer near the sink.
A whirlpool bath.
Electric underfloor heating.
Additional electric lighting - I intend to extend the lighting and run a wire down to switch outside bathroom. I am comfortable with this piece of work.
Electric Fan - I understand this requires wiring to a fused spur from the power ring protected by a 3A fuse.
Electric light over sink - I understand this can be a spur from the lighting circuit
Shaver socket - I understand this can be an earthed spur from the lighting circuit.
Whirlpool bath - I understand this should be connected to a switched, fused spur from the power ring with a rccb (the house is protected by an RCB at the consumer unit - do I still need a RCB to the bath?).
Underfloor heating - I understand this should be connected to a switched, fused spur from the power ring.
This set up would require 3 fused spurs from the power ring - can these all be taken from the same point or must each fused spur be taken from a different point on the ring?
A whirlpool bath.
